Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: spark plug question?
dblair
05-04-2013 13:56:16
according to the Nebraska test the compression ratio should be 8.34 to 1 and have a static compression of 225 psi . I run a autolite 3116 in my 450 which has like compression and a 29 venturi which gives it about 71 hp . set the timing dead on 25 degrees at 1600 rpm and run 110 octane any less on octane may melt the piston top . have fun . the gap on the plug is .025 and will cause a miss in the engine if opened to much more because of cylinder pressure . put a heavier spring in the governor it will operate a lot sweeter at 1760 to 1900 rpm . hope this helps
