TractorLinks.com
spark plug question?
v8s10
05-03-2013 17:19:11
hey guys! on to the next question for my motor build! what spark plugs should use? its c281,tisco pistons, 400 crankshaft,new 450 lp head,new valeves,springs etc,new lp manifold,new petronix ignition, new 450 cam,new cam bearings,and all other bearings obviously,stock stroke, an m carb with a bowl off a 301 combine engine with the big metering stem and a # 27 venturie,and a higher octane gas since ill have quite a bit of compresion.. my question is what should run for spark plugs?? i think whats in my stock M are d16 champions, but idk if those wouldbe what to run! any help would be greatful guys!
buickanddeere
05-26-2013 10:28:59
 Re: spark plug question? in reply to v8s10, 05-03-2013 17:19:11
14mm thread, Autoloite non resisitor 216 or the hotter non resisitor 437.
18mm thread, Autolite non resisitor 3116
general purpose
05-26-2013 07:29:01
autolite
kmcclung
05-05-2013 11:23:17
In my opion NGK AB-6 is far superior to all others been running them for several years with not one failure they seem a little hotter and work well with MSD or without they will take more fuel without fouling than any other brand ive found and ive tried them all. I will not use anything else even in a stock nonpuller
DK44H
05-04-2013 16:19:13
Here's what happend to the Champion spark plug yesterday in my 425 John Deere garden tractor. Made a helluva bang! Thought I blew a hole in the block when it happened!
dblair
05-04-2013 13:56:16
according to the Nebraska test the compression ratio should be 8.34 to 1 and have a static compression of 225 psi . I run a autolite 3116 in my 450 which has like compression and a 29 venturi which gives it about 71 hp . set the timing dead on 25 degrees at 1600 rpm and run 110 octane any less on octane may melt the piston top . have fun . the gap on the plug is .025 and will cause a miss in the engine if opened to much more because of cylinder pressure . put a heavier spring in the governor it will operate a lot sweeter at 1760 to 1900 rpm . hope this helps
southpull
05-04-2013 12:00:52
Champions are the worst plug out there. Not knocking them, it's just the truth. NGK is probably the best, but anything other than Champion is good.
LCB
05-04-2013 09:47:37
auto lite is what I use but in my opinion champion is the worst plug you can run.
mattwillson
05-04-2013 05:29:11
I m having good luck with autolite 3116
VicS
05-04-2013 16:47:51
 Re: spark plug question? in reply to mattwillson, 05-04-2013 05:29:11
Is anybody using modern (car) plugs and adapters?
mark49
05-05-2013 06:16:45
 Re: spark plug question? in reply to VicS, 05-04-2013 16:47:51
I am currently running Delco Rapid-fire plugs (no. 4) in my Massey 44. I set the gap at .045 initially and have had good results compared to Champion D18 plugs).
