TractorLinks.com
Re: head gasket with fire ring
mEl
04-13-2013 17:53:07
Mr Gasket,
I am quite sure that Doug uses the same system that I do, so for our application, yes, we have created our own solution. Doug's response was not out of line in any way as we have both had the exact same experience with Lubbock.
If I were seeking advice on an issue I would want to hear all comments so I could judge which way to proceed.
Many on forum have had bad experiences with other suppliers of the tractor pulling market and no one seems to mind hearing those comments so why should Lubbock be any different.
Look at it like Doug was looking out for the inquiring individual, I would want to know before I dumped a huge sum of money out.
mEl
Gasket
04-13-2013 18:50:25
 Re: head gasket with fire ring in reply to mEl, 04-13-2013 17:53:07
Mel -
I understand your position. You have to understand mine: Not everyone wants to explore uncharted territory with the "gasketless" design. Some people may want the simplicity of drop on a gasket and torque it down. In addition, others may be running cylinder pressures that do not require a high performance sealing system. Fortunately, Lubbock fills this need.
My experience with Lubbock is Garbage IN Garbage Out. If you send a decent imprint of a block you will get a decent gasket back. When I have had a mislocated bore, they have always made it right with me. They told me flat out: The most accurate way to have gaskets made was to tool it up on their waterjet. You can have a base gasket with bore centers programmed then have whatever size bore cut when ordered.
I guess that's one guys bad experience (dboll) countered with one guys good experience (mine).
dboll
04-14-2013 09:10:32
 Re: head gasket with fire ring in reply to Gasket, 04-13-2013 18:50:25
Mr. Gasket, I sent them a factory gasket for a pattern and I did all of the proper machine work. I don't see any garbage from my side. I called them to talk with them and see if there was anything done on my part that could have contributed to the failure to which they were no help. I have rebuilt many diesel and gas engines as we have always did our own work on the farm as well as doing jobs for others. I have also worked in a Case and jd dealership where my work was respected and I know what it takes to hold a gasket so I would appreciate you giving me the benefit of the doubt that I might know what I am talking about. Go to a national pull and visit with others, you will hear the same thing. Maybe a Model T gasket would be within their abilities.
mEl
04-14-2013 06:23:35
Gasket,
I understand garbage in garbage out very well.
We supplied Lubbock with a accurate tapping of the block surface which we still have in our posession. The finished gasket as supplied hung over the bore and would not have sealed on the sleeve flange and torqued down would have interferred with the piston travel.
I do understand the drop on and torque theory with a gasket at moderate compression ratios but fire ring failure was a problem at the CR's that we like to run.
I must defend Doug in this matter, he is my friend, we have spent some time together at his farm looking his pulling iron over and talk at times via phone and he pulls with some of the best in his area and has a few trophys and ribbons. Please do not come down to hard on him as he just says what he thinks right out front, you never have to guess where he stands on an issue, that's not a bad thing.
mEl
