Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Farmall M lack of RPM governor?
north puller
03-29-2013 09:03:02
The screw isn't touching the stop. That is because the stock linkage doesn't allow the governor control arm to move through its full range of motion.
There are 3 things to do to improve this.
1 - adjust the length of the rod from the pivot linkage to the governor arm (by bending it, or cutting and welding it) so that the pivot linkage is more "sideways" and less "up and down". This way the pivot linkage moves the rod more through its range of motion.
2 - the long arm of the pivot linkage that the rod to the governor is attached to should be made longer. Cut it, piece in about 1/2" to 3/4" of material, and weld it back together. This again will make the pivot push the rod more with less pivot motion.
3 - drill a new hole in the governor control arm a little shorter than the factory hole. Maybe 1/2" to 3/4" shorter. This way the rod will swing the control arm more.
You still won't have "full" range of motion in the governor, but you should get enough to go from a nice slow idle to 2000 rpm with stock spring.
Rust Farm John
03-29-2013 15:49:31
 Re: Farmall M lack of RPM governor? in reply to north puller, 03-29-2013 09:03:02
Thanks! North Puller your the first to offer good advice to me on this site in a real long time. Thanks for the detail!
north puller
03-29-2013 20:48:16
 Re: Farmall M lack of RPM governor? in reply to Rust Farm John, 03-29-2013 15:49:31
Rust farm, no problem. This site has helped me out over the years, and has given me the phone numbers and email adresses of some very smart people in the pulling world. Glad I can help someone else out. Sometimes it is hard sorting out the good advice from the BS, but that is half the fun. Good luck.
Jim Johnson
03-29-2013 20:33:43
Try including your email on your post and you will get a lot more good advice.
Jim
Rust Farm John
03-29-2013 21:02:15
 Re: Farmall M lack of RPM governor? in reply to Jim Johnson, 03-29-2013 20:33:43
Thank you for the heads up.
