TractorLinks.com
Re: Hard block question
1066puller
03-28-2013 18:57:42
I think 16 3/8
Cody
03-29-2013 21:59:43
 Re: Hard block question in reply to 1066puller, 03-28-2013 18:57:42
You need to have your block re-honed after you hardblock it, because the hardblock will distort the cylinders. Once that is done, you should be able to set it up as a normal engine. If I don't have any specs on a piston I usually shoot for .010-.012 piston clearance.
mlpankey
03-30-2013 07:32:08
 Re: Hard block question in reply to Cody, 03-29-2013 21:59:43
In agreement with cody
mlpankey
03-30-2013 07:49:31
 Re: Hard block question in reply to mlpankey, 03-30-2013 07:32:08
i should say i agree with cody on hardblock distorting cylinders .I do not agree with piston to cylinder bore clearance .I think he is thinking more in ring end gaps than piston to wall clearance
MLPANKEY
03-30-2013 07:53:08
 Re: Hard block question in reply to mlpankey, 03-30-2013 07:49:31
Quoting Removed, click Modern View to see Heres J@E pdf for forged pistons
http://www.jepistons.com/PDFs/TechCorner/SCPDrawings/piston_instrc4032.pdf
Cody
03-30-2013 17:20:53
 Re: Hard block question in reply to MLPANKEY, 03-30-2013 07:53:08
Loose will live!! Got to keep in mind on a completely hardblocked engine that more then likely that it is gonna get abused and overheated. A little extra clearance will save you some $$ an headaches in the long run.
