can u pull these tractors in div II or III?
ANDY E
I have an MM UB with a 403 motor can it be pulled in div 2 or 3? also have an 39 farmall m with 281 replacement block can it be pulled in div 2 or 3? pics on UB following
No. NATPA states no altered deck height. Even though its a stock deck height G motor, its illeagl deck for a UB. This manifolds are awesome, tho. Plus, there are some other differences im not even bringing up. Id LOVE to own that tractor! is it yours?
depends who you want to pull with. The M should be div 2 legal anywhere. the Moline is div 2 some places div 3 other places.
Well, for one, in DIV 2, Im not sure that 5 star propane manifold would be legal...Now I DONT PULL DIV 2, but I know that are sticklers on allis stuff..
Oops, posted only half the message...I guess I dont see any problems with the rest of the setup. I was thinking a saw something else, but I was wrong. Now, I THINK the manifold SHOULD be legal, I just dont know if it is...
TECHNICALLY some UMIL tractors came with G motors. You could get a DEALER INSTALLED G motor, but MM U's never left the factory en route to the dealer with G motors. And if one ever did, there were not significant enough amounts to add up to anything.
You are best off just to put the G crank in short blocks, and be done with it.
As far as I"ve been able to find, it was a dealer modification. It was not sold or done by the factory.
It has enough HP to pull in div 3 just wondering if it could slip into div 2? but with MPH classes I guess it does not matter!!!
I can testify Our neighbor (Jim Nelson) took delivery of a U with a 403 on LP. The block man got it done at the factory! I was to young to know the differences when it was new. But him and my dad were good friends and they were always talking about it. We had a new JD G with hi-compression pistons and gas manifold. The U would pull 4 bottoms faster than the G would pull 3. And yes when I got big enough I made me one. Vic
Looks good, let"s play. Div 2 & 3 require wheelie bars, div 3 requires kill switch. Play safe. And tires have a foot print to follow. Now where"s that sled, let"s hook.
