Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: compression after rebuild super C
Earl-IL
03-26-2013 07:47:45
Do a cyl leak down test, it will tell you if it is the valves or rings.Listen to the exhaust, carb, or crankcase breather you will hear the air leaking by. Bring that cyl to top dead center both valves closed. Apply controlled air (30--100 PSI ) using a air line pressure regulator. You can make a air adapter out of a old spark plug, weld in a hose adapter.Any question email is open. Earl
