R JD stamped wheels
gtx1967jewison
Anyone have a set of hubs &/or wheels for this?
Anyone know how much weight you loose?
How light can you get with no pony no pto/hydraulic & stamped wheels?
Thanks for any help!
I was pretty disappointed actually lost all of a 100 lbs and a whole bunch of work but I did get 18.4x38 vs 18.4x34.I think my R with smooth cover and my 250 lb self on now weighs about 7100 losing the pony and the radiator you might get to 6500. from there lighter front axle and lighter wheels no tubes ect.Paul
1949 R no pto no hyd 9 bolt rear wheels 9 bolt oliver hubs off a 1600 no pony motor/12 volt starter one 12 volt battery custom manifold/water necks farmall m rad/15 inch wheels on front 200lb driver 6300 lbs
