Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: trailer length needed
[Return to Forum]
clint skarovsky
03-17-2013 16:13:12
75.1.44.71
For you guys who haul two tractors to a pull...how long a trailer is necessary to do it easily? Sometimes I'll have the luxury of loading two NF JD A's; sometimes it will be a W6 and a JD A. I'm thinking that minimally we'll need 24' of deck with a dovetail and anything longer than that is even better.
What are some of you guys using?
Thanks
[Reply]   [No Email]
nl00sb
03-19-2013 10:18:10
142.105.177.26
 Re: trailer length needed in reply to clint skarovsky, 03-17-2013 16:13:12
heres a pic of the 24+4 or is it 23+5 i dont remember farmall super m jd a jd b
[Reply]  [No Email]
massey 333
03-19-2013 08:18:43
209.173.189.232
A little outdated,but we hauled 2 NFs on 16ft.trucks for years with no problems.Ms-44s and equal sizes.I hauled 3(2NFs-1St.)and sometimes 4(3NFs-1ST)on a 25+5,all 3-4 plow size.So unless you want to pull a big trailer,16-20Ft.plus tail is plenty.16-18K trailer is more then enough.I have 2 16'16K&1 18+2 16K that are nice easy pulling trailers,plus a 30+5 with 12K axles for serious hauling.The bigger it is,the more trouble in tight places. Your choice.
[Reply]  [No Email]
toolz
03-18-2013 22:11:14
206.221.154.149
Trailers are kinda like sheds- never big enough. My 24+5 was tight for two tractors, and real tight for one big tractor and a 4 bottom plow. I figure a 30+5 is my minimum. I have a 40' PJ with an eight foot hydraulic tail, and it's by far my favorite of the many I've owned. I'll never lift ramps again if I don't have to.
[Reply]  [No Email]
showdown
03-18-2013 16:43:35
75.213.38.182
I run a 22+2 2 nft. tractors 11,500 gross weight. Works great for me.
[Reply]  [No Email]
nl00sb
03-18-2013 15:14:24
142.105.177.26
20+4 works if u dont mind it siting on the tail 24+4 works and all is on deck both trailers i have been able to get 3 on
[Reply]  [No Email]
dblair
03-18-2013 06:44:37
67.172.201.147
hauling 2 on a 20' gooseneck with a 5' beaver tail isn't a problem but stopping it is .you will need tandem dually to stop.
[Reply]  [No Email]
OldMoIron
03-18-2013 19:08:39
71.1.126.144
 Re: trailer length needed in reply to dblair, 03-18-2013 06:44:37
I haul 2 one 5500 the other is 3500 on two axle 20ft and 5 dove. Stopping is fine I gear down take my time and always aware of others doing their fourwheeler style driving.
[Reply]  [No Email]
gtx1967jewison
03-19-2013 19:53:31
174.225.227.114
 Re: trailer length needed in reply to OldMoIron, 03-18-2013 19:08:39
I haul 2- one is 9500, other is 5000, plus 2000 in suitcase weights, extra fuel, tools, three spares (2 trailer 1 truck), cooler, clothes etc, all with an 86 F250 regular cab, single wheel, 6.9 N.A. diesel. Weighs 31480. Its a tri-axe trailer, NOT a fan of it. Hard on tires & bad for turning. But it stops fine- just keep all 6 brakes working. A tandem dual is the only way to go in my book.
[Reply]  [No Email]
dblair
03-19-2013 04:56:52
67.172.201.147
yes that's a good weight , I start having trouble at 13k with mine.
[Reply]  [No Email]
mmfan
03-18-2013 05:30:35
98.201.166.130
Here is the trailer my Dad bought a couple of years ago. Its 28ft total length, the dove tail is about 3ft. 17.5 wheels. 102" wide Its a fleetneck brand. Its just right for thease two plus a golf cart. I like this style as it is easier to load and chain everything down verses a flat deck.
[Reply]  [No Email]
JDTH
03-18-2013 17:12:11
67.4.153.220
 Re: trailer length needed in reply to mmfan, 03-18-2013 05:30:35
We use a 28' PJ Car Hauler similar to the one above. Two JD's with 11' front weight brackets. Both forward facing. Like the 102" wide, low profile.
[Reply]  [No Email]
lane Valley
03-18-2013 03:44:10
174.124.160.81
We haul a nf Allis Chalmers C, nf Farmall SH, and a nf Minneapolis Moline ZA on our 24ft upper deck and the front end of the Allis hangs down onto the 4ft Beavertail. Its a very tight fit but it works for us.
[Reply]  [No Email]
Mike in Mn.
03-17-2013 20:30:20
74.46.182.55
I have a 20 plus 6, 8 1/2 ft wide, back the wide front on and swing front to one side, drive the narrow front on and past it, works good and not too long to get around with.
[Reply]  [No Email]
LarryM
03-17-2013 20:21:54
76.210.62.93
I have a 20 +4 and it is great for two narrow front tractors because both tractors are on the deck. If you want to haul two wide front tractors then longer is the answer.
[Reply]  [No Email]
VicS
03-17-2013 17:15:50
70.195.64.108
The guys are right 25 + 5 is just right. I have a 20+5. I can haul two tractors as long as one is a NF, and the wide WF is set in all the way. They need to overlap a little. But I would buy another 20+5 again. It is big enough for me and not to heavy to pull with a single rear wheel truck.
[Reply]  [No Email]
super trucker
03-17-2013 16:49:55
99.150.165.236
I run a 25 plus 5 and really like the size. I can put 3 nf tractors on it no problem.
[Reply]  [No Email]
ubzbpuller
03-17-2013 16:35:57
99.139.212.145
Clint, I have been using a 25' with 5'dove tail trailer for years. I really like the size. I haul 2 tractors most of the time and have alot of room, I have even hauled 3 a few times. I just bought a new PJ with the same dimensions and really like it. Worth the money.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
