aluminum weight brackets
awchevy
Do any of you have some pictures of your weight brackets front, belly, and rear? I'm building some. Just trying to figure out some different designs. Thanks
go to my facebook page, there are lots pf pics there. even a crude blueprint of my front one. Totally Ballistic Pulling Team is the page...
I already looked at those on antique tractor guide site. Looking for others out there that might be willing to share there's.
Here are a couple pictures of mine. The belly bar is held on with one bolt on each side and has a flat iron strap welded on and bolted to the drawbar anchor to hold it straight. Mine are built from steel, build with aluminum and just make it fit the tractor and the amount of weight you wish to carry.
Nice looking tractor! What class do you run with that? And do you mind saying how many cubes your motor is?
A little late, I know. Here are some pics of mine that is nearly finished. Our tig won't weld aluminum that thick, so I had a former student spool gun it. He welded the cross piece near the tractor too far back, so I cut the piece to make it fit around the tractor.
It is 1/2" by 4", but I would probably do 3/8" by 5" if I were to do it again, with a 1/2" front piece. With weights facing forward, it's close to 11' but since trailering multiple tractors, we get concerned with overall length.
