Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: sleeves
Mike Genrich
03-13-2013 17:55:14
They will work fine. I have a tryed and true red diamond engine thats 4.875 on the bore running .062 darton sleeves, and a 70 oliver with 560 diesel sleeves in it. both are dry blocks. put a flange on the top and go.
B.G. Angell
03-14-2013 22:21:43
 Re: sleeves in reply to Mike Genrich, 03-13-2013 17:55:14
An Oliver 70?!
ep
03-14-2013 10:06:27
Hey Mike I am thinking of doing something like you have.Do you have water in the head and do you have trouble with heat on back to back hooks or driving in the pits?ep
Mike Genrich
03-14-2013 19:23:06
 Re: sleeves in reply to ep, 03-14-2013 10:06:27
Yes we run water in the head. I drilled a hole in the side of the stock water pump and ran a hose from there to the back of the head and it seems to work fine. I had a little trouble getting an air lock out early on but since then so far so good. I did drill a small hole in each of the conn. rods to squirt a little oil on the cyl. walls to try to cool them a little. seems like it runs a little cooler with royal purple oil.
