Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere G differential
elkcagg
03-11-2013 19:55:22
Do you press 3 pins in between the rivets, like a 3/8" dowel? I'm in favor of this myself vs welding.
Todd Spillman
03-12-2013 12:31:26
 Re: John Deere G differential in reply to elkcagg, 03-11-2013 19:55:22
3/8 pin is fine, and 3 will work. space them out about the same as the factory rivets are. make sure you have a real good center punch when you go to drill your holes so the drill bit doesnt walk on you, because the gear is much harder than the cast. split the difference between the casting and the gear and drill it out. we always put some locktight on the pin before putting it in and then pean the edges over with a punch. pinning will be more durable then welding it.
