Best aftermarket eletric water pump ? Any ideas?
I just switched my g over to an aluminum radiator. I need to put a 12volt eletric water pump and looking for a good affordable solution. Has anyone put one on their tractors that could steer me in the right direction?
Thanks in advance,
Jim
I used several mazeres over the years and never had any problems. The ones I got looked very similar to an electric Holley fuel pump, lust slightly larger.
Gotta spell it right- it's Meziere. Try "Meziere water pumps" It will come right up. Haven't ran one on a tractor, but I have on a drag car. Very reliable.
Would you be so kind as to share some pictures with us? Which pump(s) will work on an inline 6 tractor engine? Thinking of putting an electric water pump on an Oliver 88. Thanks in advance for the help.
Zeke's engineering sells a pump on ebay that is basicly a copy of the Meziere pump for a lot cheaper. They work great, I have had one for over 5 years with no issues. Just search remote water pump on ebay.
I also have a pump from Zeke's. I have had about 2 years, no problems so far.
Here is the item number from Ebay 300870988909
If you know anyone afilliated with school buses there is a pump that transfers hot water to the back of the bus for the heater and they are real good and reliable and cheap.
summitracing.com well worth the money....
CSR Universal Remote Water Pumps 925C
Large Image
$244.95
Water Pump, Electric, 35-37 gpm, Billet Aluminum, Clear Anodized, Remote Mount, Each
Check Application
Estimated Ship Date:3/25/2013(if ordered today) Would you rather pick it up? Select Location
Need it sooner?
Meziere Enterprises WP116U - Meziere Remote Electric Water Pumps
$306.93
This Substitute Part is similar to the item you requested.
