Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John deere G compression/ignition help
4010 puller
03-08-2013 14:14:12
whats the best way to time these tractors and what is the right degree for timing. Every book you look in seems to have different specs. I read a post before of setting engine on TDC, then turning distributor till spark occured;that it was timed. Is this accurate?
Which way is advanced, rolling distribotor or mag towards front of tractor?
jd b puller
03-08-2013 18:50:26
 Re: John deere G compression/ignition help in reply to 4010 puller, 03-08-2013 14:14:12
4010,
No set RIGHT way to know where to set it without a dyno.
As you roll it forward, it RETARDS it.
Depending on compression and fuel, somewhere between 18-28 degrees works good. if he"s high compression, you will have to move the governor gear a tooth to get the mag to work.
Nice thing about a mag is you can set cranking and runnng sparks independantly. You"d have to get someone to change the guts in the distributor to do that.
Never had to have stiffer springs due to compression, just RPM"s.
My mag worked fine at 11+ compression.
4010 puller
03-09-2013 04:15:07
 Re: John deere G compression/ignition help in reply to jd b puller, 03-08-2013 18:50:26
Is this a good general rule for stock or just for higher compression engines? 18-28* advance is good? That is with engine at TDC and distributor rolled counter clockwise?
