Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John deere G compression/ignition help
north puller
03-08-2013 06:43:03
Just a thought. Do you think you're getting enough flow through the needle/seat? Is it simply running out of fuel after a long, hard pull?
jd g help
03-08-2013 06:46:26
 Re: John deere G compression/ignition help in reply to north puller, 03-08-2013 06:43:03
I can check that but we are talking about riding the brakes putting it under load.. hasnt been hooked to a sled yet
BushogPapa
03-09-2013 20:16:40
 Re: John deere G compression/ignition help in reply to jd g help, 03-08-2013 06:46:26
It really would help you if you could put the tractor on a Belt..feed-grinder, Prony-brake or Fan.. Lets you work on it as it is working.. I would suggest pulling the inlet air tube to the Carb (from the air-cleaner), to eliminate other problems and verify that the choke is staying Open.. As JDB Puller said, the ignition may be letting the Fire go out.. be sure the engine is warmed-up before you try it and see if it is better.. Ron..
north puller
03-10-2013 08:25:23
 Re: John deere G compression/ignition help in reply to BushogPapa, 03-09-2013 20:16:40
Ron is right about setting the timing under load, however I would sugest you find a dyno. If you are going to use a belt, BE VERY CAREFUL when you are reaching over it to adjust the distributor/mag.
Copyright © 1997-2015 Yesterday's Tractor Co.
