farmall c motor swap bad dream turned true
nl00sb
farmall c puller worse case had a dream the other night that I forgot to drain water out of my c puller checked at the farm today sure enough big crack , will the crank from my c fit in my 230 block?, or should I just get a 135 from a local guy, done a swap for a 153 into a 230 but what if any diffrences are there between the 153 and 135 also what about the c grill and radiator can I make my c one work or do I need the super c 200/230 ones ? thanks neal
Everything will fit in to your 230 block!
Sleeves for a Su C are larger but be made fit in a 230 Block
Cliff S
