409 farmall clutch
what i mentioned worked real good. on a M-SM, you should remove the live pto drive hub on the 966 pressure plate, you can find 6 button disks for SM at a clutch shop, the pressure plate can be ordered off this site. take your flywheel, disk and pressure plate to the shop n have it all dialed in n holds pretty good for not alot of money.
all of the above is what i got in my m-ta ... use a flywheel from a super m - a 450 its 12 inch ....but i use a 986 pressure plate those were hydro asst clutches ...higher spring pressure on the plate gives leg a work out ... call ed at Leamans tractor parts in pa he can hep ya get beefy ...my clutch has a 1566 center in it for the damper on it
