More Stroker Cranks
Heres some JD cranks in the works...
How many hours do you end up with lets say a 9.25 stroke john deere crank? Seems to be big money difference from builder to builder. Not pointing fingers at anyone, just curious.
They all vary. By the time I balance the whole assembly and polish I could be pushing 25-35 hrs. Some take longer some take less. A lot of time and welding wire and heat go in to each one.
They actually are reasonably price most of the time, with that many hours into them. If done correctly and corners not cut. I received one that was so bend it trashed the bearings in half hour of run time.
