TractorLinks.com
Re: Case VAC pullers
dboll
02-15-2013 05:40:34
That would't be the one Mel put a 201 into is it? Whether it is or not a 201 is not legal in NATPA.
Cliff S
02-15-2013 12:15:26
 Re: Case VAC pullers in reply to dboll, 02-15-2013 05:40:34
Doug
No the VA mEL put a 201 in is DON FISHERS that have pulled in the past and you can not compare to a VAC anymore other than sheet metal !
I was talking about my VAC that I built to pull local pulls and dose well in 3000 3500 but is a little out powered in 4000 noncut but can get a win now and then!
My VAC has a NATPA WIN in 3000 Div 2 and a second in 3250 div 3 at tallmadge Oh but that's a weak track com paired to the other NATPA Tracks I been to!
Cliff S
MMZAck
02-15-2013 11:09:50
Is the 201 engine considered USAP legal?
Zack
VicS
02-15-2013 11:16:48
 Re: Case VAC pullers in reply to MMZAck, 02-15-2013 11:09:50
It should be! Their rules say, if it is the same no. of cylinders, mfg and will bolt in.
Mopower
02-18-2013 06:55:32
 Re: Case VAC pullers in reply to VicS, 02-15-2013 11:16:48
Unfortunately, the don't allow different deck height, even if bolt in like my 403 MM (unless it is a John Deere, then apparently it's ok). They also can't use a longer engine (Olie 77/88, Case VAC/201, IH 560/Red Dismond) unless Division 5.
Cliff S
02-15-2013 12:18:32
Vic
The 201 won't bolt in with out drilling and taping the block to make fit!
Cliff S
VicS
02-15-2013 19:26:08
 Re: Case VAC pullers in reply to Cliff S, 02-15-2013 12:18:32
Cliff I know a guy that put a combine motor in a 300. He said it bolted right in. A 300 is old enough isn't it?
Cliff S
02-15-2013 22:37:11
 Re: Case VAC pullers in reply to VicS, 02-15-2013 19:26:08
Vic
In usap it may be old enough but NATPA says production start 1959 and older for div 1,2,2t and 1957 and older for div 3,4
The other problem with the 201 is its longer block and that changes the wheelbase and that's a no no.
Cliff S
