Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: batteries
[Return to Forum]
ericsegaline
02-15-2013 00:02:03
24.91.229.82
Whats a good battery to use on a tractor with no chargeing system
[Reply]   [No Email]
mlpankey
02-16-2013 10:06:52
98.68.182.16
Re: batteries in reply to ericsegaline, 02-15-2013 00:02:03
A 16 volt turbo start battery was what i ran with a msd and no charging system
  [Reply]  [No Email]
buickanddeere
02-15-2013 11:34:56
184.151.61.232
Lots of surplus lithium Boeing 787 batteries hitting the market.
  [Reply]  [No Email]
mEl
02-15-2013 17:52:27
209.158.49.42
Re: batteries in reply to buickanddeere, 02-15-2013 11:34:56
Good one B&D, if you had one of those would you "burn" down the track LOL.
mEl
  [Reply]  [No Email]
ppmengineering
02-15-2013 10:17:21
63.227.69.17
We use a big, I believe 1150cca commercial battery from NAPA. We mount it out front so we really don't worry about it's weight.
  [Reply]  [No Email]
6pack
02-15-2013 10:03:23
64.85.139.221
Optima makes a really good one... Used to have one in race car. With electric fan, and no charging system, worked very well!!! Just need to keep a battery tender on it when not in use
  [Reply]  [No Email]
LCB
02-15-2013 09:53:12
67.142.167.21
I have have the best luck with jell batteries like they use in boats if you have them up front on your weight bracket.That being said when i went to MSD box i gave up and strated runnin an alerantor.I dont have mine hooked that way put you can put a switch on them and shut it off while you are pulling and then turn it on and let it charge when you are not hooked to sled.
  [Reply]  [No Email]
VicS
02-16-2013 17:36:56
70.195.66.17
Re: batteries in reply to LCB, 02-15-2013 09:53:12
I have my alt on a switch. It will charge a lot more. It is a little Nipp one without a regulator. Type in smart batteries L-Lion (spe lling) I think a 40 anper hr one just weights 15 lb.
  [Reply]  [No Email]
buickanddeere
02-17-2013 11:45:16
209.240.116.36
Re: batteries in reply to VicS, 02-16-2013 17:36:56
Careful when pouring high current and high voltage into any battery, lithium in particular.
If the battery is warm to the touch, it's plenty.
  [Reply]  [No Email]
VicS
02-17-2013 15:23:39
70.195.64.26
Re: batteries in reply to buickanddeere, 02-17-2013 11:45:16
I'm not using a L-Lithium battery in any of our tractors, But would like to in my golf cart. 3 of them are $1800 and the charger is 600 more. If you go for the 100 amper hr. ones they are like $6000 Maybe they will get cheaper! Vic
  [Reply]  [No Email]
MLPANKEY
02-17-2013 18:43:38
98.68.183.178
Re: batteries in reply to VicS, 02-17-2013 15:23:39
Quoting Removed, click Modern View to see turbo start 16 volt battery weighs. 32 lbs
  [Reply]  [No Email]
Dieselbear
02-15-2013 08:02:44
50.193.137.17
Are you running a electric fan or water pump, if so are they on a thermostat, MSD box or points, elec. fuel pump, all this matters?
  [Reply]  [No Email]
rustred
02-15-2013 07:18:57
69.58.16.5
you would want a new one and make sure it has a high cca. rating so it last a while till able to charge it.
and is this on diesel or gas as a gas will run down a batt. way faster.
worked with tractors for years that dont charge, just make sure your batt is fully charged at start of day.
  [Reply]  [No Email]
leej
02-15-2013 06:11:29
216.73.235.175
I just can't believe my eyes? Am I reading this question correctly?
Or were you out on adrinking spree last night?
ggp
  [Reply]  [No Email]
gtx1967jewison
02-16-2013 08:11:38
174.225.133.176
Re: batteries in reply to leej, 02-15-2013 06:11:29
The gas one may take a bit less to start, but the gas burns power the whole time its running-for spark-....diesel dont.
  [Reply]  [No Email]
rustred
02-15-2013 07:28:57
69.58.16.5
huh ???. the starter dont care if the battery is being charged after engine is running, just as long as it has enough amps left for the next start. dont believe i am seeing an answer like this.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
