| Tractor Pulling Discussion Forum |
Topic: Farmall H pistons
[Return to Forum]
| Author |
[Modern View]
| 48farmallH
02-10-2013 18:18:31
206.53.196.77
I have been lurking around this sight for a long time soaking up great info, now i signed up to ask a question. Where is the best place to get a good set of high compression pistons? Vollbracht's? Tisco? or a NOS set of fire craters? I have the cam out gettting ground right now and plan on milling a .100" off the head. I also have port matched the head and intake. I would like to get as high of compression as possible while still running high otcane pump gas. Also, any ideas on a carb? Super H? 350?
I am also looking for a set of 12 x 38 dropped rims if anyone has a set or knows of a decent deal.
I pulled last year with a turbo setup that i built, but i want to run it a bit more legal this year.
https://www.youtube.com/watch?v=cJHLzoTe0aQ
Any advice would greatly be appreciated.
This post was edited by 48farmallH at 18:21:53 02/10/13. |
[Reply] [No Email] | |
| north puller
02-11-2013 14:55:38
68.171.231.87
Re: Farmall H pistons in reply to 48farmallH, 02-10-2013 18:18:31
| I would not mill the head like that. You are considerably weakening the head by doing so, and it will be more prone to cracking. If you are looking for more compression than an off the shelf piston has to offer, then look to the custom builders. For a little more money, you will have a much better product. Carb and cam have to work together based on your intended RPM. |
| 48farmallH
02-11-2013 19:31:33
206.53.196.77
Re: Farmall H pistons in reply to north puller, 02-11-2013 14:55:38
| Thank you north puller, is there an exceptable amount to mill or just leave the head alone and take care of compression with pistons and stroke? I spoke with a couple engine builders today about pistons but neither could give a number on compression even with the head casting numbers. |
| north puller
02-12-2013 03:30:44
68.171.231.80
Re: Farmall H pistons in reply to 48farmallH, 02-11-2013 19:31:33
| | I think that with a smaller engine you could get away with 9:1 compression on 93 octane pump gas. Unless you have a LP head, you arnt going to get that compression with off the shelf pistons. If you're going to get custom pistons then there's no reason to mill the head any more than necessary to get it flat. Milling the head will not gain you much, and with an off the shelf piston, it might be the difference between 7 and 7.5 compression. Cam timming will show more of a difference on a compression tester. As far as off the shelf pistons go, I really have no idea which ones are the best. For custom, have you tried the Farmall builders? I think that Baker or Lemmons should be able to build pistons based on your head casting number. They should know the cc's already. I don't know for sure, but I think that ALL the custom builders use Arias or Ross for smaller pistons like that. Difference is that the farmall guys should already know how big of a bump to put on top. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
