Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: HUBS STUCK!!!
[Return to Forum]
B.G. Angell
02-09-2013 03:48:36
208.54.44.209
What is the best way to get hubs that are stuck to an axle unstuck? I have tried heating them with a torch and just cant get them off with a hammer. do they make a reasonable set of gear pullers that big? On a 70 oliver.
[Reply]   [No Email]
Dave Thompson jr.
02-10-2013 17:30:14
64.184.126.173
 Re: HUBS STUCK!!! in reply to B.G. Angell, 02-09-2013 03:48:36
Us a port a power apply pressure to both sides. Then smack the hub with a hammer and it will come loose.
[Reply]  [No Email]
algar
02-10-2013 14:50:52
74.47.115.218
I had a case 600 that would not come loose with a 50 ton bottle jack.Adam Cam told me to use the largest all thread i could fit attached to a thick flat plate with a solid bar between that and the axle,tighten the all threads .Then hit plate squareley with a 16+ lb hammer. Probably 2 or 3 hits each side,and they were loose. The hyd jack had just enough cushion where hitting with the sledge was not doing any good.
[Reply]  [No Email]
LarryM
02-09-2013 19:56:34
76.210.62.93
I built a puller for a 9 bolt hub that had a bolt going to each hole and a 1" threaded rod and nut in the center. By the time I got it off the 1" threaded rod I used had mushrumed out and formed a little point that went right into the center of the axle. There is no way I would have gotten them off with out breaking them had I not built it.
[Reply]  [No Email]
Gordey
02-09-2013 16:48:52
209.91.107.229
We built a puller and used the power-pack at the same time, never used heat though.
[Reply]  [No Email]
B.G. Angell
02-09-2013 15:47:21
208.54.44.209
Dang! Apparently wheel hubs are a common problem. Thanks guys for all the replies.
[Reply]  [No Email]
baldwin racing
02-09-2013 15:10:09
74.79.154.169
see if you can get liquid nitrogen. from a local welding supply store....you will have to barrow a container like what they put bull siemen in.....pour it on axle....wearing gloves and becarefull.... it will shrink axle being so cold....on both sides then hit hub.....
kelly
[Reply]  [No Email]
puln70
02-09-2013 10:51:20
199.191.115.119
I made a puller that fit around the hub & used a 10 ton bottle jack,got torch out got it hot & still wouldn't budge.So I found a guy w/a big hyd press,took it(the axle & hub w/wheel) to him & it took quite a bit of pressure but that came off.
[Reply]  [No Email]
LCB
02-09-2013 08:55:29
67.142.167.23
If it is rust that is holding it on get it as hot as you can then cool it down with water as fast as you can and this will often times break them loose.
[Reply]  [No Email]
Mopar-Harris
02-09-2013 08:45:47
70.195.1.160
25 years ago we took a set of axles out of a 70 Oliver down to Cat's shop in KC. Put them in a 150 ton press. 1st one shook the shop when it let loose at 120 tons; second let loose at 90....
Pete
[Reply]  [No Email]
west alton river rat
02-09-2013 08:21:33
64.254.50.205
20 yrs ago my buddy was trying to move the wheels on his JD 4230. We soaked it with wd-40 tried to drive in chisels ,4 hours nothing. We called our JD shop forman he said hit that s.o.b as hard as you can straight down with the biggest sledge you have. 2 hids an it was broke loose. WILDMAN
[Reply]  [No Email]
49A
02-09-2013 06:58:41
72.161.26.105
Used a port a power to put pressure on it while tapping on it. Broke loose. May need to move port a power from side to side
[Reply]  [No Email]
mark49
02-09-2013 06:22:44
69.128.229.21
I built a puller like Craig said and used a large gear puller at the same time on the last hub I pulled off a Massey 44. I tightened the puller until it started to bend (1 1/8" steel, used lots of PB Blaster and then had to hit the back of hub at the axle with a sledge hammer (piece of aluminum between to cushion the blow). Took 2 or 3 evenings to get it to move.
[Reply]  [No Email]
nl00sb
02-09-2013 05:27:17
142.105.177.26
we used to loosen the bolts up and drive around and or use the tractor under close watch till they broke loose
[Reply]  [No Email]
Super Trucker
02-09-2013 05:10:15
99.117.30.62
If there anything like my 36 HP 70 get ready for the biggest battle you have ever fought. It took heat to the tune of 900 deg and a 20 bottle jack bottomed out pressure and a BFH to get mine off. TOOK 3hrs each side. Did you guy's get the rod?
[Reply]  [No Email]
B.G. Angell
02-09-2013 05:53:49
208.54.44.209
 Re: HUBS STUCK!!! in reply to Super Trucker, 02-09-2013 05:10:15
Sure did. really appreciate it!
[Reply]  [No Email]
craigco
02-09-2013 04:46:54
69.171.160.158
Some people make their own puller with a piece of heavy steel across the axle and all thread going to the hub.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
