TractorLinks.com
Re: stroke crank for farmall
awchevy
02-05-2013 10:14:26
OK thanks. If I pull the sleeves out of a 350 block hat sizes pistons do u recommend running? And in a 300 block can you pull the sleeves and put a oversize bore 350 sleeve?
H-66
02-05-2013 17:09:56
 Re: stroke crank for farmall in reply to awchevy, 02-05-2013 10:14:26
If you are pulling the sleeves out of a 350 or 300 block 3.8125" is the bore size to use unless you are going to hard block it. How much do you want to spend? If you want 5.75" stroke call Murphys he will set you up for less money in one stop than you will spend trying to piece it together yourself.
awchevy
02-05-2013 19:19:06
 Re: stroke crank for farmall in reply to H-66, 02-05-2013 17:09:56
How big can you run with it hard blocked?
H-66
02-06-2013 17:04:02
 Re: stroke crank for farmall in reply to awchevy, 02-05-2013 19:19:06
Not sure how far you can go with hardblock, I have not tried it yet. Gary Baker could point you in the right direction there. Also Jeff down at Murphys will have more insight than me.
Mike n Mo
02-05-2013 10:48:54
AWchevy, Can't help on piston size to use, I'm not that familar with the H-350 engines. I'm close to Murphy's shop and stop in there every now and then, so I have some knowledge of what he's got going on there. Good luck with your project. Mike
