Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: 3 in journel on a stroker crank hold togeather
[Return to Forum]
big G puller
01-29-2013 08:41:12
67.242.212.159
will a 3 journel on a 9.5 stroker crank with a 7 3/4 bore hold togeather or break?
[Reply]   [No Email]
buickanddeere
01-31-2013 05:17:31
184.151.61.102
 Re: 3 in journel on a stroker crank hold togeather in reply to big G puller, 01-29-2013 08:41:12
A 3.5" journal has 1.361 times more material than a 3.0" journal.
[Reply]  [No Email]
Indiana Ken
01-31-2013 19:12:36
66.249.232.131
 Re: 3 in journel on a stroker crank hold togeather in reply to buickanddeere, 01-31-2013 05:17:31
Yes, this would be correct for cross sectional area. The strength of the journal in tension is proportional to the cross sectional area. However, for a crankshaft, strength in torsion and strength in bending are more important than strength in tension.
If I could repeat your calculations for clarity: The cross sectional area is proportional to the diameter raised to the second power (diameter squared). For a 3" journal we have 3^2 = 9 and for a 3.5" journal we have 3.5^2 = 12.25. 12.25 divided by 9 = 1.361; increase in strength in tension.
The strength of the journal in torsion and in bending is proportional to the journal diameter raised to the fourth power. For a 3" journal we have 3^4 = 81 and for a 3.5" journal we have 3.5^4 = 150.06. 150.06 divided by 81 = 1.85; increase in strength in torsion and bending.
In conclusion the 3.5" journal is nearly double in stength for the more important torsion and bending modes.
With all respect - hopefully this adds to your post. Ken
[Reply]  [No Email]
buickanddeere
01-31-2013 19:51:37
209.240.120.229
 Re: 3 in journel on a stroker crank hold togeather in reply to Indiana Ken, 01-31-2013 19:12:36
It's all good with me. Left the torsion and
bending out for simplicity.
Actually the 4th power is going to take some
refreshing and thinking about. It's been a while.
Have to wonder with the airflow being limited by
valve and and port size along with the short cam
timing. Is gaining that last 1/2" to 1" of stroke
that requires a skinny cam, 3" journals and a
relocated cam really worth it?
[Reply]  [No Email]
buickanddeere
01-30-2013 12:20:06
184.151.63.251
She has to last in order to place first
[Reply]  [No Email]
Tree Topper
01-30-2013 11:10:15
209.248.167.84
I have a 9.75 stroke, 6.375 bore, about 9 to 1 compression. Been running since 2004 with no problems yet. Has been pulled pretty hard in 10,200 lb. class many times. Works real well.
Oh yes it has a 3 inch journal!
[Reply]  [No Email]
Big G puller
01-30-2013 15:41:55
67.242.212.159
 Re: 3 in journel on a stroker crank hold togeather in reply to Tree Topper, 01-30-2013 11:10:15
well iv been running this crank for 7 yrs with 3 in journels 7.5 block thats 832 cubes block went bad so if im gonna replace block to 7 3/4 im going with a new crank shaft befor it breaks
[Reply]  [No Email]
Mike n Mo
01-30-2013 13:27:14
13.13.123.100
Tree Topper, Your 3" journal should be very reliable at 622 cu in. We're running 3" journals on A's with more cubes than that, and just replaced a crank after 6 years (before it broke). The engine in question will have 896 cubes, almost half again more than yours, and needs the bigger journal to have decent reliability. Mike
[Reply]  [No Email]
Tree Topper
01-31-2013 09:54:13
209.248.167.84
 Re: 3 in journel on a stroker crank hold togeather in reply to Mike n Mo, 01-30-2013 13:27:14
Yes I know this is not a very big G as compared
to what is being built these days, but this set up has worked very well for me. Been very reliable. Don't use the engine up very often even in heavy classes. Lots of fun.
[Reply]  [No Email]
blackangus
01-29-2013 19:58:18
70.198.1.191
Ive got a3.5/8 with 3.5 journal in my 70 very tight
[Reply]  [No Email]
Brent50G
01-29-2013 13:45:04
174.228.65.114
Yes for a couple years as long as u keep it from detonating
[Reply]  [No Email]
Mike n Mo
01-29-2013 09:34:13
13.8.123.100
You'll be better off with a 3.375-3.5" journal size. The 3" will hold for a while, but the bigger ones will last a lot longer.
[Reply]  [No Email]
Josh Blackburn
01-29-2013 09:28:06
174.239.0.250
Why risk it. 5020 3.5 journal. You can still fit 9.5 in easy.
[Reply]  [No Email]
big G puller
01-29-2013 09:34:42
67.242.212.159
 Re: 3 in journel on a stroker crank hold togeather in reply to Josh Blackburn, 01-29-2013 09:28:06
josh how much to do a 9.5 or 9.75 with 3.5 journels
[Reply]  [No Email]
Josh Blackburn
01-30-2013 04:25:11
174.252.225.39
 Re: 3 in journel on a stroker crank hold togeather in reply to big G puller, 01-29-2013 09:34:42
1500 includes flywheel-crank-driver assembly balanced as one unit.
[Reply]  [No Email]
Lynerd
01-29-2013 09:20:06
72.192.116.62
Yes Lynn
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
