Anonymous-0
I HAVE A 400 CASE WHAT CAN I DO TO MAKE A GOOD STOCK PULLER FOR AROUND A 100HP IS THERE SOMETHING ON A LOWER BUDGET
depends on your budget, it will cost $500 or more just to get your block bored for bigger sleeves like 4 5/8, let alone the cost of sleeves, pistons, a cam and head work ,a stroked crank will cost in the area of $1000, 100hp is easily do-able but no build up is cheap
You mean from Case Flambeau Red to Case Power Red? Was there another brand of tractor painted a similar color?
I know of no stock puller that has a hundred hores unless its a 966 or 4020 a stock 400 should be running 55 to 60 hp if you are going for that hp then get in the class you should be in
