you work in a welding shop, make some plates, pre-heat the axle and have at it with 7018 electrodes (axles need to be removed), I have seen many clamp-on's cracked over the years.
Outsidersag, l do sell custom made steel hubs. Made from steel, are removable and adjustable, locked in place with set screws and use a key. 734-678-9688
I have dealt with docjoe several times always been happy.He is a strait shooter and what ever he tells you is the way it will be.
(quoted from post at 07:08:34 01/26/13) Call Pete at Cap Bros LLC makes a nice light weight adjustable Hub 816-308-8879
Here are the CAP Bros MotorSports hubs on a DC Case. 22lbs each.
Pete
docjoe, could you make a pair of lightweight 9 bolt hubs for a Farmall H? If so how much would you get for them?
Thanks,
Jim Henke
