Farmall A updates
Hey everyone been awhile since i last posted, just giving an update on my build. Welded up a set of wheelie bars and a couple of weight brackets for it. Got rid of the stock air cleaner in favor of a cone shaped paper filter. Any ideas on coaxing a little more power out it? high compression pistons or should i just run it stock? Oh and i forgot to mention made it to the last pull of the season and on its first run ever i got a second place in the 3000 lb class!!
high compression pistons will help you quite a bit and do your head over give it a port job and work on the carb and you will notice large increase in power!
Cliff S
my 1939 Farmall A in 2500 pound class a few years back !!!!
Cliff S
