Pulln Sled ( 500#-4000# ) for Sale $5000.
Anonymous-0
Full load (72',144',216'). Calibrated for percentage and or distance. Have pulled walkbehind garden,up to "B" JD. (3hp to 175hp) Call for info, 909-997-7040.
DUH, was a 175hp hybusa motorcycle engine in a 1050# gardentractor. guess you also wanted to see the 5hp "B"
DUH. I didn't see anything about 5hp. The way the parenthetical is formatted, I thought the 3hp went with the walk-behind and 175hp went with the B JD, but I guess I expect too much from adults sometimes when I assume they learned how to reference their own writing correctly.
I agree with Lamont. It reads that it will handle from a garden tractor to a B John Deere or 3 to 175 Hp. The order makes you assume that the latter (the B) is 175 hp not the garden tractor.
Try again----handled (3hp-175hp)garden tractors, operator+walkbehind = 500#. Also handled a 48"B" @ 4500#. Sled wt. 4900# with 2500# base wt.box. (transfer wt. of 4000#) Unit has 3 hitch ht. points,with 3 diff.chain lengths. Also stopped a WD Allis, R Moline, and H Farmall, 9N Ford, and a Chevy Luv Trk. Sorry got a discussion started,just want to sell my sled. You remove the 2# bottom chuck(chain) replace with a 44" ballcup hitch,lock the pan and tow down the highway. thanks,call 909-997-7040
...OR you could post it on this site in a section called "Classifed Ads" or "Photo Ads." Those sections are usually where people post items they are trying to sell, AND where people look if they are looking for something to buy. There are sub-sections in each, and the "Photo Ads" are for ads with pictures! Why are you sorry you got a discussion stared? This is called the "Tractor Pulling DISCUSSION Board." DUH. (I'm usually not this sarcastic, but most times I can give as good as anyone else if they whiz me off!)
