TractorLinks.com
Re: enough cooling?
Indiana Ken
01-22-2013 07:28:04
How does the horse power of the Honda Civic engine compare to the horse power of your WD 45? If you provide similar air and water flow to the radiator it should provide similar cooling for the WD 45 in terms of horse power. Note the Honda would have used a pressurized cap and this should be retained to prevent boiling. Boiling over is harmless if you catch the fluid however localized boiling inside the engine can cause hot spots and promote detonation.
buickanddeere
01-22-2013 14:05:46
 Re: enough cooling? in reply to Indiana Ken, 01-22-2013 07:28:04
As long as there is sufficient cooant flow. Some localized nucleate boiling will do no harm. And actually run the engine cooler than a pressurized system with 50/50.
