TractorLinks.com
bracing a john deere g pulling motor
sammy G
01-20-2013 10:22:36
is there a good way to brace the underside of the frame on the g to support the big 7 3/4 block because u have to grind so much out of the crank case i think its gonna be weak mabey sum tubing or sumthing from the back any ideas?
FactoryFarmer
02-05-2013 15:30:49
 Re: bracing a john deere g pulling motor in reply to sammy G, 01-20-2013 10:22:36
Heres mine
GoJDpuller
01-22-2013 10:19:36
I thought they make these blocks longer so you keep the sleeves out of the case
GoJDpuller
01-22-2013 06:48:06
sammy G
01-22-2013 11:04:58
 Re: bracing a john deere g pulling motor in reply to GoJDpuller, 01-22-2013 06:48:06
no thats and 8 in from extreme murphys sleves go in the crank case
GoJDpuller
01-22-2013 06:41:02
Unstyled G Guy
01-21-2013 09:14:46
If your going to go 7-3/4" block then it would be best to have a machine shop cut out the crankcase. We've done 2 crankcases for that size block in our machine shop on a mill and the wall's are THIN, even with the patches. I would also suggest that you wait until you actually get the block before having the crankcase bored... I know people are waiting on these blocks but have only seen one actually show up.
sammy G
01-21-2013 12:51:36
 Re: bracing a john deere g pulling motor in reply to Unstyled G Guy, 01-21-2013 09:14:46
can it be milled out on the tractor of will it have to be stood up right?
Unsettled G Guy
01-21-2013 13:21:44
 Re: bracing a john deere g pulling motor in reply to sammy G, 01-21-2013 12:51:36
Crankcase has to be taken out, meaning rearend and front end have to be taken off so that just the crankcase goes on the mill. Also better if you take tranny out. If you haven't split/broke down a John deere G that much before it could seem like a big ordeal but it really isn't that hard and doesn't take that long
JohnDeereJimOhio
01-20-2013 17:19:03
This is a pic of my weight bracket and hitch off the tractor.. Other is one on but u can't see it as well..
JD PHIL
01-20-2013 13:22:38
I would like to see pic's also somebody post a few.
JohnDeereJimOhio
01-20-2013 10:53:13
I have a piece of flat stock that connects my belly bar to my hitch to support mine.. I'm not running a huge motor but piece of mind if it would fly apart I can send you pics
sammy G
01-20-2013 11:12:54
 Re: bracing a john deere g pulling motor in reply to JohnDeereJimOhio, 01-20-2013 10:53:13
that would be awesome if ud send me some pics thank u
Little Big B
01-20-2013 11:24:47
 Re: bracing a john deere g pulling motor in reply to sammy G, 01-20-2013 11:12:54
Hey I know of just the thing you need. Give me a call sometime and I'll get you talking to the right guy on the braces.
Derek Holdren 605 929 2797
