TractorLinks.com
Re: 300 rebuild
redkev44
01-18-2013 12:37:27
So to put 350 pistons in my 300 i will need to bore the block, and the wrist pins are different size other then that good to go.
D Slater
01-18-2013 13:45:22
 Re: 300 rebuild in reply to redkev44, 01-18-2013 12:37:27
Just purchase a sleeve and piston set for a C-175. Now most if not all places sell the same S&P set for a C-169 and C-175. Blocks are the same size, All sleeves were the same OD size for both. If the engine serial number is below 48049 (farmall tractor engine) put adapter piston pin bushings in the rod end. If that serial # or above the rods are the same as a C-175. Not very common to find a 300 engine anymore with 3-9/16 pistons in it as most were already changed to 3-5/8. Have you checked yours?
