DC Case carb air cleaner
Anonymous-0
I am removeing the air box and was wondering if it best to the K&N style of air cleaner right on the carb or is it better to have a strait tube with the air cleaner on to straiten the air flow into the carb or maybe there is no difference I dont know?
(quoted from post at 17:29:44 01/17/13) I am removeing the air box and was wondering if it best to the K&N style of air cleaner right on the carb or is it better to have a strait tube with the air cleaner on to straiten the air flow into the carb or maybe there is no difference I dont know?
A straight piece back along the tank with a filter on it is worth HP. If you are not running one , a Marvel Schebler will be a nice addition for the DC with an 830 venturi in it. Less restrictive than the zenith with the booster venturi. The throttle shaft must match the DC as far as lever and idle screw positions. they are made in all configurations.
mEl
