Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: sleeveless m pistons
Underdog Moline
01-15-2013 10:24:38
Pin Diameter and deck height will be the same if you are using an M rod, crank and piston"s you will just need to size the bore if your M engine was sleeved to 4" the OD should be somewhere in the 4 1/8" Dia with a step at the top you should be able to run a regular 4 1/8 after insuring that tolerances are acceptable. Remember that in the life of the M-SM-400-450 there were 2 different pin sizes
Copyright © 1997-2015 Yesterday's Tractor Co.
