| Author |
[Modern View]
| clampdaddy
01-15-2013 07:42:58
166.137.209.173
I've been saving up for a while so I can do a few mods to my '48 model A all at one time. I'm getting real close now and was wondering if it would be more cost effective to buy an aftermarket head or just have the factory head worked over. I'm not going with a big cube motor. Stock stroke and .125 overbore gas pistons. Is an $1800 head going to make more power than a reworked factory head on a small cube motor? |
| clampdaddy
01-22-2013 20:19:53
50.8.151.226
Re: Aftermarket Deere head? in reply to brandon j, 01-15-2013 07:42:58
| jlo said: (quoted from post at 02:23:13 01/23/13) we have a head that is ported polished and has big valves. we are not pulling Deeres anymore and would sell this one |
Milled? How far? Who did the work? What are you asking?
This post was edited by clampdaddy at 20:20:32 01/22/13. |
| jlo
01-22-2013 17:23:13
38.123.17.30
Re: Aftermarket Deere head? in reply to clampdaddy, 01-15-2013 07:42:58
| Michael Bay
01-16-2013 06:16:25
50.124.249.222
| Ill let you know... going with the extreme tractor parts head on my 51" puller. raise the compression a bit and let a little more flow. had a stock 51" head shave a 1/4 inch on it when we bought tractor and it didnt work. Also, like to get josh"s number to see about carb work. |
| clampdaddy
01-17-2013 20:43:09
50.8.151.226
Re: Aftermarket Deere head? in reply to Michael Bay, 01-16-2013 06:16:25
| Quoting Removed, click Modern View to see
That's the head I was thinking about. My e mail is always open so let me know how it works out for you. When you say that you shaved the factory head and "it didn't work", what do you mean? Not the compression gains that you had hoped for? |
| Michael Bay
01-19-2013 06:31:07
50.42.173.18
Re: Aftermarket Deere head? in reply to clampdaddy, 01-17-2013 20:43:09
| Not enough compression for are liking and even though a lot of people say head work doesn"t matter it does. |
| clampdaddy
01-15-2013 21:11:29
50.8.151.226
| Josh Blackburn
01-15-2013 12:02:40
174.252.245.81
| 9 by 6.125 A with cyclone head making 99 hp. Your head with 600 put in it will flow all the air you need. Put the other 1200 into a big journal 9 inch crank |
| Early B
01-15-2013 09:10:39
97.73.64.150
| We have a late A thats all stock except .125 over w/ the head & manifold worked over & a hot mag . It runs pretty good for what it is.We pull 4500-6000lb 2nd gear w/13.6s no problem |
| GoJDpuller
01-15-2013 09:04:11
198.228.228.177
| No to the after market head |
| Sadowsky
01-15-2013 10:16:48
71.80.90.67
Re: Aftermarket Deere head? in reply to GoJDpuller, 01-15-2013 09:04:11
What he said ^^^. That head is way overkill for anything other than gigantic cubes. |
| bill bo
01-16-2013 04:45:36
66.87.104.5
Re: Aftermarket Deere head? in reply to Sadowsky, 01-15-2013 10:16:48
| I agree, the Murphy head is way to big. |
