Farmall h front end
awchevy
Ok i got a question. I wanna put a c bolster on my h. What hubs are you guys running so i can use press steel rims. Ive seen it done before. Just wondering on the hubs and bearings to use. Or any other front ends that would work. Thanks for the info.
If you want to use your h front 350 ultilty hubs and bearings will fit and you can use 6 hole imp or tractor rims.
Do you guys know of any for 240/340 narrow fronts ends for sale? Ive looked around here and had no luck.
The 240/340 has 6 bolt hubs but you will have to make an adapter plate to match the T bone to the mounting plate under the H. The 300 utility hubs on a H is a very minimumal amount of weight loss..
