clutch coupler?
dgerth
If that's what it's called, where can I acquire one of these devices to eliminate the hand clutch? Also, does it require a split to install same device? This is on a WD used for pulling.
tks,
dgerth
you do have to break it in half. there is a 4 bolt coupler on the hand clutch assembly for it to slide on the splines on the shaft. just get another one of those couplers and put them back to back and bolt together and slide back on the shaft where the hand clutch assembly is now. then you just have a straight shaft and it wont slip.
you welcome. we have 2 wd45 pullers we did this with and have been pulling one for 7 years and have had no problems. have pulled it up to 6500lbs and it only weighs 3500 lbs empty. this will fix the hand clutch slippage problem.
