JD G breaking crankcase.
JDJACK
Trying to post link to you tube video of JD G pulling and breaking.
If link doesnt work is titled, CrackingaDeere.m2ts.
Anybody know this tractor or puller? What happened? I am guessing that a rod broke?
http://www.youtube.com/watch?v=bzYfcD43R3w
Guess I don't know how to make a link.
Just copy title and put in google search bar.
Maybe somebody else could make a link to video.
In order to get the 7.5" or bigger pistons in a g you must grind the sides of the main case paper thin .They fail once in a while .Paul
Yes I know the guy that owns it. It has been fixed and is back pulling again. The failure was not due to case being ground out. If I remember correctly it broke the crank or broke a rod. Either way that was the cause of busting the case
With the big bores and thin cases, don't you somehow strap the block and frame bake to the case so the bolts in the front of the case don't take all the load?
