TractorLinks.com
Re: 720 diesel
Gpower
01-11-2013 11:11:05
10-16mm???? Thats gotta be the dumbest statement on this board. Deere never used 16 mm plungers in any of thier pumps. Deere never made a 6X12 tip either. Obviously you have never rebuilt or made CNC parts for the 2 cylinder pumps, because you would have known that statement is false, and cannot be done. The barrel walls would be paper thin....or not even a wall. Deere used a 10mm and a 13mm barrel and plunger assembly in the 2 cylinder era, nothing else. The reason the 10mm flow the same as a 13mm on the bench is because the helix is ramped down on the 13mm plungers. All Deere wanted to do is increase pressure and injection timing by going to the 13mm plungers.
While there are 15mm barrels and plungers being made, the wall failure rate is inevitable, to thin to keep plungers from seizing over time.
To answer the original posters question correctly, yes spending money on pumps and injectors is one area to improve. Which head do you have? Is it a later black dash tractor?
What are you wanting to accomplish with the tractor?
buickanddeere
01-11-2013 15:55:13
 Re: 720 diesel in reply to Gpower, 01-11-2013 11:11:05
That is what I said. The 13mm pumps have the fuel delievered while the piston is closer to TDC than a 10mm pump can.
Deerepower53
01-11-2013 11:33:47
It is the black dash 720 tractor. I want to get some extra Hp out of the tractor for pulling.It will pull stock classes so I don't need to go wild. I would like to know what is the best option head work or fuel work?
Gpower
01-11-2013 12:20:59
 Re: 720 diesel in reply to Deerepower53, 01-11-2013 11:33:47
For the money youd spend on the head, your not going to gain a lot in return. IE port and polish, get the intake and exhaust manifolds port matched where the openings line up for smooth flowing, no steps or lips. Most of the time they are close, but little things like that dont cost a lot and you can do them.
Gpuller who has posted on here has a 720 diesel, and I built his fuel injection system for his tractor. Maybe he will chime in here and comment on what he thought about it.
I would first check your fuel pressure, see what it running for psi under a load. Lets start there. 30-50 psi under a hard load is good, I have run electric pumps to keep it around 100psi before, but did not see any real gains in that, but it did not stumble either.
Convert your air cleaner to a dry air type. Good clean air with minimal restrictions goes a long way. You should have 13mm pumps in your tractor with 6 hole .010 dia injector tips...that was factory for them. If the pumps are Bosch pumps I can get you bigger barrels and plungers, as well as injectors to help.
