TractorLinks.com
lightweight radiator
Nick from MD
01-10-2013 21:00:02
I want to put a light radiator in my wd 45. what would you all recommend as a good cheap one to put in it. this tractor will only be used for pulling.
algar
01-12-2013 20:22:22
 Re: lightweight radiator in reply to Nick from MD, 01-10-2013 21:00:02
I have found that the fan fromm a Ford Taurus HO has one of the highest cfm outputs tha helped my 6 cyl gas deere
showdown
01-11-2013 17:31:17
I put a civic one in mine off e-bay, with the e-fan no thermo. This seems to work good, I haven't pulled it yet. You will have make some custom hoses cause the civic rad. is 1.25 dia. in and out lol..... $64.00 free frieght.
Jim Johnson
01-13-2013 07:40:49
 Re: lightweight radiator in reply to showdown, 01-11-2013 17:31:17
You can take the radiator to any good radiator shop and they can change the inlets and outlets to what ever size and position you want, I did and the price was not very high. The one I used had the neck on the side and I had it moved to the center and also moved the return.
Jim
6pack
01-11-2013 10:48:04
 Re: lightweight radiator in reply to baldwin racing, 01-10-2013 21:00:02
Works good
http://www.ebay.com/itm/Civic-EG-EK-SI-EG6-B16A-B16B-B16-Bolt-On-Aluminum-Radiator-Red-Radiator-Hose-/200876635058?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec52e33b2&vxp=mtr
perrycountyfarmalls
01-11-2013 14:55:53
 Re: lightweight radiator in reply to 6pack, 01-11-2013 10:48:04
6pack,
do you currently use one of these radiators? what do you have it in, I'm considering something like this for my 460, but I want to make sure I have enough cooling.
thanks, Rusty
6pack
01-11-2013 15:17:00
 Re: lightweight radiator in reply to perrycountyfarmalls, 01-11-2013 14:55:53
Oliver 88 w/320... Have the electric fan to run too, but not always on... 1 thing you have to do is, make it so any air that comes through grill HAS to pass through radiator.... I used card board and duct tape when I put it in to make a shroud around it, but now I ripped it all out to use aluminum sheet metal.... Oh! I am using a stock water pump, but I am gonna try an electric shur-flo? Rv pump of some sort... I will be putting it back together in a couple weeks and try to take a pic
There is an additive I use called 40 below that helps reduce water temp, i only noticed about 15 degrees cooler...I use that and just water... No thermostat just a 7/8 hole in a plate....
Look on ebay as there are some bigger hot rod radiators to use too, but cost a lot more
perrycountyfarmalls
01-11-2013 15:27:11
 Re: lightweight radiator in reply to 6pack, 01-11-2013 15:17:00
I'll be about the same motor wise, and planned on an electric fan and stock waterpump also.
I run.. I think its called engine ice in my 4 wheelers...maybe something similar.
Thanks for the help!!
showcrop
01-11-2013 05:41:06
Go to your local salvage yard and get one from a Honda or similar.
brentp4455
01-11-2013 08:33:45
 Re: lightweight radiator in reply to showcrop, 01-11-2013 05:41:06
or an oooooold chrysler minivan.
j bronk
01-11-2013 10:18:53
 Re: lightweight radiator in reply to brentp4455, 01-11-2013 08:33:45
I bought a reman rad for an "88 manual shift caravan for my Jd A. It works great and only cost $65.
504
01-11-2013 16:29:41
 Re: lightweight radiator in reply to j bronk, 01-11-2013 10:18:53
Toyota Corollas, around 85,86 use a center fill top tank.
