Electric Water Pumps?
I got one from summit thats 20gpm and I am going to try a 5gpm sprayer pump. 20gpm might be ok if you have it hooked up to the thermostat but for running all the time thats too much flow.
I would try a 5 gpm from Northern. They are cheap and if one isn't enough try two. One isn't enough to plow with but is enough to pull with. You aren't going to drive it over a 1/4 mile anyway. Some guys don't run anything. Pulled a minie-rod once no radiator or pump. Just a surge tank with a 15 lb. pressure cap.
