| Tractor Pulling Discussion Forum |
Topic: farmall m brake seals
[Return to Forum]
| Author |
[Modern View]
| farmall m 421
01-09-2013 18:46:34
68.171.231.85
I need to replace the brake seals in my M. I already have the tin covers off and the drums off. What is the procedure to unbolt and remove the casting that holds the seal? Do I need to remove the trans top to do this? Not a big deal if I have to, just looking for some direction from someone who has done this. Thanks. |
[Reply] [No Email] | |
| dandk
01-11-2013 05:20:16
174.102.67.132
Re: farmall m brake seals in reply to farmall m 421, 01-09-2013 18:46:34
| Timken #417344 just done it this summer. Slow Burn is correct, Do Not take bull pinion carrier out without first removing the bull gear. Seal can easily be changed without doing it. |
| Slow burn
01-10-2013 14:16:36
174.231.18.20
| U can get the seals at napa or car quest, if u take the old seals out 1st they can match them up. Don't take out the bull pinion carrier, u will brake it. I can get u a part number for the seal if u need. I will also walk u threw it if u like just give me a call. 937 726 4121 |
| MisterT
01-10-2013 05:56:03
216.248.71.226
Re: farmall m brake seals in reply to VicS, 01-09-2013 18:46:34
| Do a google search for Farmall M bull pinion oil seal. |
| Mike in SD
01-10-2013 04:44:52
209.62.233.11
Re: farmall m brake seals in reply to Tempola, 01-09-2013 18:46:34
| Quoting Removed, click Modern View to see
You don't have to remove the casting at all to replace the seal. Drill 2 hole opposite of each other in the outer housing of the seal and use 2 punches to pry the seal out. They also make a seal puller attachment for a slide hammer just for this application. Also get your new seals at a bearing house rather than IH if you can, as they will be about 1/2 price and the same brand. |
| Tim Yates
01-10-2013 04:33:06
96.240.186.167
| Do not have to pull the top off. After removing brake hub and the bols on the housing that holds the seal you can use bolts to thread in the holes that are threaded in the housing. As you tighten them it will force the housing to come out of the tranny. Do not try to remove the next housing behind it as damage will occure without removing the bull gear first. |
| farmall m 421
01-10-2013 04:38:47
68.171.231.83
Re: farmall m brake seals in reply to Tim Yates, 01-10-2013 04:33:06
| | Thanks! Can I buy seals from an auto parts store, or do these have to come from IH? |
| Tim Yates
01-10-2013 04:36:58
96.240.186.167
| Had a brain fart. Pry out that housing, the housing behind it is the one I was describing that does not need to be removed. Been awhile since I did the last one. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
