Yesterday's Tractor Co.
Shop Now View Cart
Re: Engine oils
Gary Baker
01-05-2013 14:18:49
The problem with diesel oils is no zinc after 2006. So newer diesel oils dont have zinc aditive. Gasoline car oils are better in that respect. Schaeffers still offers diesel oil for pre 2007 diesel engines and it has zinc in it. Ask your supplier if pre2007 diesel oil is still available.
Dave Thompson jr
01-05-2013 16:28:51
 Re: Engine oils in reply to Gary Baker, 01-05-2013 14:18:49
Gary years ago I used to work for a trucking company that had Cat 3406 engines in all of there trucks. We used Rotella t 15-40 in all of them and changed it every 10 thousand miles. the engines would go a million miles with only having the rod and main bearings changed every 300 thousand. Might change a head gasket now and then and waterpumps and an injection pump other than that the oil always done its job. Why wouldnt you use that oil in your engines. I run it in everything that I own. Ive never torn a truck engine apart or anything that that was used in that was dirty or a mess inside.
01-05-2013 19:03:24
 Re: Engine oils in reply to Dave Thompson jr, 01-05-2013 16:28:51
because Case, deere and others have better oil than rotella. as for my pullers I just use Bomgaars or Harvest King 10w40. Farm diesels get Case No.1 30w
Gary Baker
01-05-2013 18:02:51
Dave, the goverment made the oil companies stop using zinc in there diesel oils and pretty much ruined the oil. I would not use it in my lawn mower.
Dave Thompson jr
01-06-2013 09:24:31
 Re: Engine oils in reply to Gary Baker, 01-05-2013 18:02:51
Gary well it was 20 years ago when I worked for that trucking company. Where I work at now they use recycled oil in the engines we build. I know you lhave probably done your homework on engine oils like you do everything else that you build or design. But I dont believe rotella is a bad oil lots of engines are still running it today.
01-05-2013 20:49:09
Gary I forgot to say I am getting the old formula, pre 2007. Also it is a lot cheaper. Vic
