TractorLinks.com
Re: IH H spark plugs
DK44H
01-01-2013 15:03:22
Second.
rustred
01-01-2013 16:27:45
 Re: IH H spark plugs in reply to DK44H, 01-01-2013 15:03:22
i use champion d16's. all i hear is their junk, have proved to my self that they are a better built plug. i was changing plugs in my 400 which had autolites. one was siezed and broke off. i removed it with an easy out. what i found was the body was way thinner than the champions. and i also have found more faulty autolites then champions in my tractors so thats my reason to stick with champion. and also thats what they came with. and also i like the silver finish on them . thats my reasons.
buickanddeere
01-03-2013 07:35:52
 Re: IH H spark plugs in reply to rustred, 01-01-2013 16:27:45
A Champion that is not resistor or is not the dreaded dual gap . Is a different and troublesome animal than the mostly reliable plain non resistor Champion. That said and even though I'm not a Ford fan per say. But I do keep Autolite 3116, 216 and 437 plugs on hand. Solid core plug wires too.
buickanddeere
01-03-2013 13:53:14
 Re: IH H spark plugs in reply to buickanddeere, 01-03-2013 07:35:52
Sorry, inytended to say that dual gap Champions and resisitor plugs of any brand. Are more troublesome that a plain non resistor plug of any brand.
gtx1967jewison
01-01-2013 19:50:19
You probably know this but i believe the D16 is colder than the 3116 & probably better with high compression.
Nick from MD
01-01-2013 20:16:45
 Re: IH H spark plugs in reply to gtx1967jewison, 01-01-2013 19:50:19
I was told a d 21 champion was what want to run, it's supposed to be a hotter plug. any other opinions on this?
rustred
01-01-2013 21:04:10
 Re: IH H spark plugs in reply to Nick from MD, 01-01-2013 20:16:45
it all depends on what you are doing with the tractor. for putsing around the yard stop and go ... yes. but in the field working under full load its d16 as the tractor came from factory with. i use mine in the field also. everyone jumps on the band wagon and bashes champions all the time without giving a reason or any proof of plug failures. i tryed both and have better luck with champions. another example i have is... i bought a massey 44 on auction sale they did not start it. i then started it and it was missing but what to do now, so i started to drive it home about 60 miles. it just kept missing and only running on 2 cyl's. so i drove into another farmers yard and asked if he had any old spark plugs i could buy cause i saw he had a d case sitting there. he gave me 2 used d16's from that case and i put them in the massey that had autolites which 2 were dead . then the massey ran like a top all the way home. paid 400.00 for the massey and drove it home 60 miles.
Nick from MD
01-01-2013 21:13:07
 Re: IH H spark plugs in reply to rustred, 01-01-2013 21:04:10
the tractor is just for pulling its higher compression than stock I'm just curious what kinda plug works best for that application. thanks everyone for their responses. how long did that 60 mile ride take that's awesome?
gtx1967jewison
01-03-2013 16:36:58
 Re: IH H spark plugs in reply to Nick from MD, 01-01-2013 21:13:07
Generally higher compression mandates a colder plug at some point, depends on fuel octane, mixture rich/lean, & coolant temp. The hottest plug that doesn't cause detonation is whats desired. Old Chiltons manuals have nice pictures of plugs describing how to 'read' the plugs & determine proper mixture & plug heat range.
Good luck!
gtx1967jewison
01-03-2013 16:36:57
Good luck!
Nick from MD
01-03-2013 22:47:15
 Re: IH H spark plugs in reply to gtx1967jewison, 01-03-2013 16:36:57
thank you that is good info. exactly what I'm looking for
rustred
01-02-2013 06:55:47
guess you would have to check the plugs after some pulling to see how they are doing. should be alright. it took less than 5 hrs.
