Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
BN Puller ??
showdown
12-30-2012 18:31:43
Will A BN Farmall pull any better if you put a short shaft axle in to narrow it up like a Farmall A?
Cliff S
01-01-2013 08:48:28
 Re: BN Puller ?? in reply to showdown, 12-30-2012 18:31:43
Vic
With a little bit of weight on the left side there balanced then there like any other tractor!
a lot easier than moving the clutch pedal and the brake pedals around and the steering to go with a seat on these little tractors!
Vic you seen my BN pull and there good pullers in 2500 to 4000 With some additional Power in a div 2 non cut class!
Hope my BN turns RED instead of Rust this summer!
Cliff S
farmallstrong
12-31-2012 09:05:19
We had a wheel weight on the left side which was enough to balance the BN when I was younger. We took it off when we put the 16.9x24s on to be able to still get into 2500lbs class. We pull from 2500-4000 lbs classes. We had a set of 12.4x36s on the back for a pulling season but the stock first gear in a BN is pretty tall which made it hard to lug down so low on the rpms to stay under 3mph for the horn class around home. The 36s were alot of fun in the open classes tho.
Cliff S
12-31-2012 14:17:45
 Re: BN Puller ?? in reply to farmallstrong, 12-31-2012 09:05:19
Travis we need to get together and Play in 2013!
Will you and
your Dad be at Tallmadge this Year?
Cliff S
farmallstrong
12-31-2012 15:11:54
 Re: BN Puller ?? in reply to Cliff S, 12-31-2012 14:17:45
Cliff
We are not sure yet. We will sure try but won't be bringing the tractor.NAPTA don't like her...
Cliff S
01-01-2013 08:58:46
 Re: BN Puller ?? in reply to farmallstrong, 12-31-2012 15:11:54
Trsvis
I will be there at lease with the Su C but if I bring any other tractor a friend of mine will run it!
It won't be the BN but maybe my C or VAC!
Cliff S
Cliff S
12-31-2012 07:18:19
my BN pulls fine just the way it is!
Cliff S
Super Trucker
12-31-2012 04:33:26
Leave it a BN. I run a B and A farmall the A has the 153 motor and we are having traction issues. My B does pretty good but being over 250lbs moving weight to the left wheel is a challenge. If I had the parts I would change it to a BN and make the A a BN also. We have probably 10-15 BN's pulling here.
Super Trucker
12-31-2012 10:17:54
 Re: BN Puller ?? in reply to Super Trucker, 12-31-2012 04:33:26
This is my oldest boys tractor. Just a regular old B . That's his 2nd place trophy. The fat guy is me.
ShaggyM
12-30-2012 20:54:50
I pull a Super A once in a while and it is a little hard to get enough weight on the right side.
I use a belly bracket and its all on the right side.
nl00sb
12-30-2012 18:43:37
i have found narrower the beter in most cases
VicS
12-31-2012 15:06:41
 Re: BN Puller ?? in reply to nl00sb, 12-30-2012 18:43:37
Why don't you guys just move the seat! Like the Allis guys do?
