TractorLinks.com
John deere G 8 inch stroke
Ben R
12-30-2012 16:28:29
Do you have to do any clearance work to get a 8 inch crank in a g?
ericsegaline
12-31-2012 14:45:42
 Re: John deere G 8 inch stroke in reply to Ben R, 12-30-2012 16:28:29
GIVE JOSH BLACKBURN A CALL I BUILT MANY PULLERS OVER THE YEARS AND HE BEEN FAR THE BEST CALLS YOU BACK KEEPS YOU INFORMED GIVE HIM A CALL 989 277 5366 GOOD GUY
2-banger
12-31-2012 08:38:27
Ive got the 8in motor forsale in parts ad..it will fit in easy just top of case has to be cleananced..by crank case cover...nice motor if u dont want to cut case and go big..its all about how much money u want to spend..not everyone can afford $4500 for a big bore block...iam going with a bigger stroke probaly still using stock block..be careful who u deal with for parts.. id give josh blackburn a call if your getting new stuff
Jd A 51 puller
12-31-2012 09:01:41
 Re: John deere G 8 inch stroke in reply to 2-banger, 12-31-2012 08:38:27
Nicely said!!! What is the bore of the pistons you have for sale? Thanks
2-banger
12-31-2012 14:55:54
 Re: John deere G 8 inch stroke in reply to Jd A 51 puller, 12-31-2012 09:01:41
6 3/8
jd b puller
12-30-2012 20:31:03
I've seen 8.25" with A rods. A little clearance and the back and a little to the camshaft.
Next year, you'll be asking what it takes to put a 9.25" or 10" in, and if your +0.125" MW pistons will work. The answer to those questions is, 9.25", not bad, 10" quite a bit, and no, your old pistons won't work.
Ben R
12-31-2012 13:19:44
 Re: John deere G 8 inch stroke in reply to jd b puller, 12-30-2012 20:31:03
Thanks for all the replys guys.
Actually for what im doing i probably dont even need the 8 inch stroke but i thought i would ask about it. But at least now i know what ill be doing "next year".
JDGnut
12-30-2012 20:10:46
If using an A or G rod you will also have to notch the cam.
buickanddeere
12-30-2012 19:42:28
Depends on the journal diameter. And if using a stock rod or an aftermarket offset cap rod with cap screw style bolts. Should be able to go more than 8" with the offset cap rods and an A sized rod bearing.
2-banger
12-30-2012 17:41:21
top of case has to be ground a little...it will clear back of case
