TractorLinks.com
Re: voting out the light classes
jd b puller
12-29-2012 07:48:48
Brad, if that's your concern, here's what we do down here. It's a little weird and doesn't make any sense the first couple times. Put the weights on, take them off, but after you do it a few times the break between classes and the way it is, everyone is there for most of the pull.
Even the mixed up order gets mixed up every pull, with 4 different sequences.
#1 Pull order:
1. 7200 lb. Stock
2. 3700 lb. Super
3. 5200 lb. Stock
4. 2700 lb. Stock
5. 4200 lb. Modified
6. 4500 lb. 5MPH
7. 3200 lb. Stock
8. 4700 lb. Super
9. 5700 lb. Stock
10. 7200 lb Super
11. 8200 lb. Stock
12. 5200 lb. Super
13. 6700 lb. Stock
14. 4700 lb. Modified
15. 4200 lb. Stock
16. 5500 lb. 5MPH
17. 7700 lb. Super
18. 5700 lb. Super
19. 9200 lb. Stock
20. 3500 lb. 5MPH
21. 5200 lb. Modified
22. 6200 lb. Stock
23. 6200 lb. Super
24. 4200 lb. 7.5MPH
25. 8200 lb. Super
26. 6500 lb. 5MPH
27. 4700 lb. Stock
28. 4200 lb. Super
29. 10,200 lb. Stock
30. 3700 lb. Stock
31. 6200 lb. 7.5MPH
32. 9200 lb. Super
#2 Pull Order:
1. 4500 lb. 5MPH
2. 8200 lb. Stock
3. 4200 lb. Super
4. 4200 lb. Modified
5. 6200 lb. Stock
6. 7200 lb. Super
7. 4200 lb. Stock
8. 4700 lb. Super
9. 9200 lb. Stock
10. 4200 lb. 7.5MPH
11. 6700 lb. Stock
12. 5200 lb. Super
13. 4700 lb. Modified
14. 5500 lb. 5MPH
15. 7700 lb. Super
16. 3700 lb. Stock
17. 3700 lb. Super
18. 5700 lb. Super
19. 7200 lb. Stock
20. 2700 lb. Stock
21. 5200 lb. Stock
22. 6200 lb. Super
23. 5200 lb. Modified
24. 3500 lb. 5MPH
25. 8200 lb. Super
26. 6500 lb. 5MPH
27. 4700 lb. Stock
28. 10,200 lb. Stock
29. 6200 lb. 7.5MPH
30. 5700 lb. Stock
31. 3200 lb. Stock
32. 9200 lb. Super #3 Pull Order:
1. 6200 lb. 7.5MPH
2. 3200 lb. Stock
3. 4500 lb. 5MPH
4. 8200 lb. Stock
5. 7200 lb. Super
6. 4200 lb. Super
7. 4200 lb. Stock
8. 4700 lb. Super
9. 6200 lb. Stock
10. 4200 lb. Modified
11. 5200 lb. Super
12. 9200 lb. Stock
13. 3500 lb. 5MPH
14. 7700 lb. Super
15. 4200 lb. 7.5MPH
16. 5700 lb. Stock
17. 4700 lb. Modified
18. 5500 lb. 5MPH
19. 10,200 lb. Stock
20. 6700 lb. Stock
21. 8200 lb. Super
22. 5700 lb. Super
23. 3700 lb. Stock
24. 5200 lb. Modified
25. 6200 lb. Super
26. 4700 lb. Stock
27. 6500 lb. 5MPH
28. 2700 lb. Stock
29. 3700 lb. Super
30. 5200 lb. Stock
31. 7200 lb. Stock
32. 9200 lb. Super
#4 Pull Order:
1. 3700 lb. Stock
2. 3700 lb. Super
3. 7200 lb. Stock
4. 7200 lb. Super
5. 4500 lb. 5MPH
6. 5200 lb. Stock
7. 4200 lb. Modified
8. 4700 lb. Super
9. 6200 lb. 7.5MPH
10. 2700 lb. Stock
11. 7700 lb. Super
12. 3500 lb. 5MPH
13. 5200 lb. Super
15. 8200 lb. Stock
16. 3200 lb. Stock
17. 5500 lb. 5MPH
18. 5700 lb. Stock
19. 4200 lb. Super
20. 9200 lb. Stock
21. 5700 lb. Super
22. 4700 lb. Stock
23. 8200 lb. Super
24. 6200 lb. Stock
25. 6200 lb. Super
26. 5200 lb. Modified
27. 4200 lb. Stock
28. 6500 lb. 5MPH
30. 4200 lb. 7.5MPH
31. 6700 lb. Stock
32. 9200 lb. Super
46mpuller
12-30-2012 06:12:09
 Re: voting out the light classes in reply to jd b puller, 12-29-2012 07:48:48
jd b puller that is retarded if i had to sling weights that many times at a pull i would say f*c* it and stay home
jd b puller
12-30-2012 06:59:51
 Re: voting out the light classes in reply to 46mpuller, 12-30-2012 06:12:09
I said that the first couple times too. But makes for a nice break between hooks so you aren't scrambling to get weighted up.
