Yesterday's Tractor Co.
Shop Now View Cart
Re: pertronix ignition
12-26-2012 15:18:51
Take a look here, this should help. Good Luck!
tom grim
12-26-2012 15:44:14
 Re: pertronix ignition in reply to HammerTime, 12-26-2012 15:18:51
Sorry for the slowness, anyway I have assumed you have a 12v - ground system so here is how it should be hooked. The power coming from your ignition switch needs to be hooked to the + side of your coil as well as your red wire heading into the module. The black wire from your coil needs to go to the - side of the coil. If all that is correct and still no spark install your voltmeter(this may sound wrong) red lead to - side of coil and black lead to a good ground with the module hooked up. Have your buddy crank the tractor and read what the meter says.0 volts is a wiring problem. 1 to 3 volts is a bad module. What you want to see is a fluctuating signal between 1.5 and 12 volts. Hope this helps, Tom
12-26-2012 16:56:11
 Re: pertronix ignition in reply to tom grim, 12-26-2012 15:44:14
thanks i will try that tomorrow,
12-26-2012 15:41:07
thanks will check it out tomorrow
