| Tractor Pulling Discussion Forum |
Topic: JOHN DEERE 620
[Return to Forum]
| Author |
[Modern View]
| mkr100
12-25-2012 19:49:27
108.131.86.204
How much can I shave off the head to raise the compression without getting in to problems. The engine is .125 over and cranking compression now is around 120psi. What pressure should i shoot for and how much power will be gained. |
[Reply] [No Email] | |
| 2-banger
12-26-2012 07:10:38
70.192.15.18
Re: JOHN DEERE 620 in reply to mkr100, 12-25-2012 19:49:27
| Ive done all the hds on my tractors..i cut. 150 off it only makes like 5 to 10lbs of psi diff if u open hd up and grind brows out..u need to lengthen rods out to really make diff....josh blackburn has done few for me...my 60 runs like 220psi now made huge diff but if u want to use it to farm with too i would keep it in 180 to 200 psi range |
| buickanddeere
12-26-2012 11:50:29
184.151.61.113
Re: JOHN DEERE 620 in reply to 2-banger, 12-26-2012 07:10:38
| I would work of volumetric efficiency and rpm before going to such high compression ratios. The rate of return on conversion of compression pressure vs combustion pressure into work is dropping by 175psi and not worth the rate of return past 200psi. That last 1-2 HP isn't worth the extra 10 octane points required in the fuel. |
| Josh Blackburn
12-26-2012 15:14:11
174.232.14.127
Re: JOHN DEERE 620 in reply to buickanddeere, 12-26-2012 11:50:29
| Theories vs Dyno results. Had a b at 180 psi. Bumped it up to 230 psi and picked up 7 hp. No other changes at all. So in my opinion compression is your friend. Cams and cam timing is why most deeres struggle. Most tractors were off from factory and then you throw and grind on the wore out cam and gears and you are further off. Never have I had a tractor at 175 vs 220 psi only make 1-2 hp more. Yes race fuel is expensive but my 7 hp was worth the extra 4 bucks a gallon on the track. |
| north puller
12-26-2012 04:02:59
68.171.231.80
| | How many hours are on the motor? If not too many? You can re-ring/rebuild withour the worry of a ridge at the top. If you are serious at all, you want new high compression pistons, and/or longer rods. I have heard of .250" oe more being taken off a deere head, but the more you remove, the weaker the head gets. You may find your pushrods get too long as well. |
| buickanddeere
12-25-2012 20:40:32
209.240.119.15
| The mistake was not installing LP pistons when it was apart. Then having the cam re-ground and the followers re-faced. You won't find a lick of difference on a dyno let alone the track. Between stock, 45, 90 and 125 over bore. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
