| Tractor Pulling Discussion Forum |
Topic: Re: wd45 stroker crank question
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| wi50
12-25-2012 09:24:50
174.255.101.222
In some of these smaller engines I use a Farmall H or 350 rod that I do some clearance work on and countersink a different rod bolt. At 5 1/2 " stroke there is verry little block clearance work. The Farmall rods use a canted cap and are plenty strong.
Usually a carnk will cost $750-850 for one of these 4 cyl cranks for welding and grinding. Stroke length really doesn't make much difference as it's just a little more welding work.
I have billet rods made here and depending on the rod journal diameter and rod profile, cap angle etc. they will clear real well out to 6" stroke with verry little work. Any more and then there's just more clearance work to do.
I don't like to post to much cam information. But the profile really will depend on your cylinder head, rpm range and engine size. I see a lot with the same advertised duration but different lobe seperation angles and faster ramps depending on the engine combination.
WD45 blocks are not as asrong as later ones and that 5 1/2 stroke is a good range to be in with that crank and block. You can keep a good rod ratio there and not beat your parts up to bad.
It all depends on how much money you wish to spend. What piston you want to use, engine size, etc. The limeting power factor will alwayse be the head, manifold and carb. And of course your abilities to tune the engine.
I have a set of the billet rods and farmall ones ready at the shop. I'll take a picture and post after Christmas when I get back to work.
This post was edited by wi50 at 09:44:39 12/25/12. |
| Lyle/Ruthie Adams
03-20-2013 20:18:44
166.182.3.204
Re: wd45 stroker crank question in reply to wi50, 12-25-2012 09:24:50
| wi50 ! Do you do WD crankshaft Stroking and where are you located?? Thanks, Lyle |
| Ralphy3
01-23-2013 20:15:50
75.187.225.157
| What's your contact info. I would like to get in touch about getting parts and work done. Thanks |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
