Sigourney IA
Anonymous-0
Just read the rules and it looks like you dont have to have a kill switch. Just wondering because planing on going down there this year and dont want to show up and not be able to pull.
I WOUID LIKE TO PULL MY 1952 JOHN DEERE G BUT
YOUR RULES STATE THAT LETTER TRACTORS CAN NOT RUN DUPLEX CARB. ARE YOU THINKING ABOUT CHANGING THAT RULE. THANK YOU LARRY FROM MICHIGAN
May be a dumb question but why wouldnt you want a kill switch seems like it would be better for safety?Thanks
I like to use the "intent of the rule" approach to questions like this. While there is nothing specific in the rules that says you cannot run a longer/taller block in the open class, there is a factory HP limit for the light open classes 3500 and 3750. So, since an 88 sized tractor/block is not allowed to pull 3500 and 3750, I would apply the same logic to your situation. You cannot pull a 77 with an 88 sized block in 3500 or 3750 open.
Its OPEN. What good is the word "open' if thats not what it means? I am always bewildered by this situation whenever a club does this. Then they cry that turnout is falling?
Please explain. To most people open means run what ya brung. Limiting hp directly limits competition & attendance. We have a local club that limits horsepower to 33% over factory in open, & RPM to 10% over. This is NOT 'open' in any other motor sport! Oh but then they have a v-8 antique tractor class.....(?!?)
Jon and the crew at Sigourney run a good pull with a decent set of rules and very little problems so don't try to stick your finger in their eye if that's what you are trying to do. Let their rules be what they are. 75 tractors in the 5500 national? I don't think they have a problem with turnout!
Obviously "Open" in the context of our rules does not mean "anything goes".
This tractor pull is a once a year event that directly benefits(fund raiser) the local Expo Fair Board. The Fair is a traditional summer 4H/FFA event for the local youth. I have sole responsibility for interpreting/enforcing the rules, that have been in place since the inception of the pull over 20 years ago. I inherited this responsibility from my deceased father. The local Expo Board members and community volunteers are great about supporting the pull with a great deal of labour hours. Our priorities for the event are safety, consistency and creating an inviting environment for the continued success of the event.
We don't have club politics or annual rules meetings voted on by small numbers of local pullers. The rules have remained largely untouched since their creation. I try to be as fair as possible to each and every puller and will seek out experts when I need to for specific makes/models when something comes up that I don't know. We always apply common sense to the interpretation of the rules in order to be as fair as possible.
Above all, if anyone has questions/suggestions, I am always available at the end of the track checking the RPM of each and every tractor after they pull.
Oh please dont think im knocking anyone! Thats not the point it sounds like a much better event with higher turnout than anything from lose to here. I just was wondering why clubs have a class called ' open' & then its not. It seems there are other classes for limited stuff & im just wondering if you build a full out machine & cant go in open class yhen how/where can you compete with it? I dont wanna spend 10k on a tractor i cant pull?
Sorry for the confusion & thanks for any input
Open in SE iowa is pretty much run whatever speed you want and not "run what you brung" type rules. Some of the "open" tractors that meets the pulls rule go scary fast in that building anyway let alone anything that would go faster. Just my opinion and not trying to speak for Jon.
Funny I heard no Case tractors from South Dakota would be allowed. All this talk about the pull needs to slow down, I have a ton of work to be done before then. Although it will be great to see everyone!!!
after last years track I would like to get a low and a half gear, my 2nd is like a jd 3rd gear and by 5000 I didn't have enough, other years I ran 2nd all the way to 6000
there's limited shut down area at the end of the track in case something bad happened so anything goes might not be a good idea there, it is a fun pull to attend whether a person pulls or not if one is able to
